Cylinder wall scratches after new piston rings
94 views 4 replies 2 participants last post by  JSAG
#1 ·
Howdy!
I picked up my freshly bored and honed B18C from the machine shop a couple of weeks ago. According to the shop, everything was healthy and within specs! Pistons ring grooves have been cleaned up too. So I've thrown in a new set of piston rings (Honda 13011-PR3-003). All rings rotated freely, and the gaps have been correctly positioned. I've cleaned and coated the piston and the piston walls with engine oil prior installation, and slid in all four pistons without too much hassle (cyl 2 required a retry).
Now after rotating the crank by hand a couple of times, I've noticed some vertical micro-scratches appear on some areas of the upper portion of the cylinder walls. Running my nail won't catch on any of them. You cannot appreciate them but you definitely can see them. I've been searching on the Internet and it seems I shouldn't be too much concerned and just run it, but I'd like to hear from any of you having gone through a rebuild process of a B-Series. Maybe a debris? Should I carry on without worrying too much? Or should I take a couple of steps back?
What would you recommend?
Thank you!
#3 ·
No, nail's not catching. The first picture shows the most prominent one, but it's not even to be felt. It looks way more as if it had been penciled. All others I'd really say are almost microscopical. Funny thing is that they don't extend to the bottom, but only on the upper quarter. I don't think my cylinders are conical :D
The machine shop has a really good rep here in Germany. They slightly rebored the walls, leaving it stock at 81mm, which I've roughly measured too. I'm using Honda OEM rings. Honestly, I assumed with those I was good to go and skipped checking gap clearances at each cyl, not expecting to be too small but otherwise if at all.
Did I rush too much? Was this a mistake? Should I remove all pistons and measure?
Thanks!
