stiff and hard brakes
2K views 10 replies 3 participants last post by  p27rpy
#1 ·
when i apply pressure on the brakes, its really hard to press down on them just to get the car to stop. be it at 10 mph or 40 mph. the rotors are new, like 8 months old, pads were changed at the same time. 94 teg, and i checked all the brakes, lines and rotors. mstr. cyl?, or do i need to change the brake fluid and bleed. or is it something that i'm not seeing?
#2 ·
i really need to press hard down on them just to try and slow down...no pumping on the brakes, can't even do that.
#3 ·
maybe it has something to do with the power brakes? check that brake booster line, that's all I can think of
I'm curious what the problem is too
#7 ·
this is weird huh?, man i feel so good that i'm not the only one, i've done searching and everyone says that to bleed the lines and put new fluid, but no one has followed up on the brake project so i'm not sure if that would save my problem, but then again i'll get desperate and then try anything.
#8 ·
from a site i just read...
1. Your power brake booster is bad.
2. The vacuum hose to your brake booster is leaking or is disconnected.
3. There is a bend or kink in a brake line or hose which is causing a restriction.
4. Your brake pedal is caught on something, or it is not free to pivot on its support.
I dont' have the problem, I just like to know the answer haha
EDIT:link
